11 years agospi_command from Linux
Hy guys, I'm using a CycloneV-SoC. In the FPGA, I have instanciated the Altera-SPI-Master-controller and connected it to the lightweight-H2F-bridge. Linux is running on the HPS. What should I d...
11 years agoHi Charly78,
There is an example in the 14.01 release for SPI: C:\altera\14.0.1\embedded\examples\software\Altera-SoCFPGA-HardwareLib-SPI... That should help you. Also, you can find the HWLib files in the directory as well: C:\altera\14.0.1\embedded\ip\altera\hps\altera_hps\hwlib\src\hwmgr I hope that helps. Sue
