OrF
3 years agoSource synchronous Input Constraints Edge Align
Hi
following Altera/Intel course of about the source synchronous constraints https://learning.intel.com/Developer/learn/course/168/play/1632:223/constraining-source-synchronous-interfaces
I ...
- 3 years ago
You use the edge-aligned equations. The phase shift from the PLL happens inside the FPGA, not at the inputs, where the data and clock are still edge aligned. Use -setup and hold-period as shown.
sstrell
3 years agoYou use the edge-aligned equations. The phase shift from the PLL happens inside the FPGA, not at the inputs, where the data and clock are still edge aligned. Use -setup and hold-period as shown.
