17 years agoSOPC/Quartus II "pass through component" problem
Hi Everybody, I have Quartus 9.0 running on Cyclone III Board with Bitec's HSMC DVI daughterboard on it. I have Clocked Video Input (1080p60 DVI input) and Clocked Video Output (1080p60 DVI ...
17 years agoWith regards to the VIP clock rate. The clock rate you need to run at depends heavily on your design.
If all you are doing is passing the data through, then you should have your clock rate be at least equal to the video clock rate. If you have enough elastic buffering you can actually run at a slightly slower rate due to the horizontal and vertical intervals of the video. Jake
