17 years agoSOPC/Quartus II "pass through component" problem
Hi Everybody, I have Quartus 9.0 running on Cyclone III Board with Bitec's HSMC DVI daughterboard on it. I have Clocked Video Input (1080p60 DVI input) and Clocked Video Output (1080p60 DVI ...
17 years agoto formjk :Thanks formjk. I now have a much better understanding of things.
I will try what you told me. to jake: No, I never connected CVI directly to CVO. I always had either a frame buffer or my custom passthrough component in between CVI and CVO. They are using the same clock source. With my custom pass through component though, I had 50Mhz only, I am not sure if that would be enough in the first place. Instead of my initial design where I only had CVI ->pass through->CVO, will stick to what you and jake mentioned which is I believe like this; CVI->pass through->Frame Buffer->CVO There is no hope for my "CVI ->pass through->CVO" design to work with the high throughput of the DVI input/output, right ? I will most probably bug you guys again on my way, hope you don't mind :) Thanks both of you for your understanding and patience , Tyler
