17 years agoSOPC/Quartus II "pass through component" problem
Hi Everybody, I have Quartus 9.0 running on Cyclone III Board with Bitec's HSMC DVI daughterboard on it. I have Clocked Video Input (1080p60 DVI input) and Clocked Video Output (1080p60 DVI ...
17 years agoDid you try connecting the CVI directly to the CVO? I don't expect it will work. There needs to be enough elastic buffering between the two to allow for any position mismatch in their respective video streams. Also, are you clocking the output of the CVO with the same clock as the video input?
