16 years ago
SOPC own component: design library "work" does not contain primary unit
hello again,
I built my own component and added a Altera Megafunction - the FIFO.
When running SOPC builder there is the following error:
design library "work" does not contain primary unit "my_fifo"
in the "my_component.vhdl" i added this line:
use work.my_fifo;
Why is there the mentioned error in SOPC builder?
Thanks for every hint!
    Is my_fifo a package? If it is just a component you shouldn't try to include it with a 'use' line. Just declare the component in the architecture and instantiate it.
    What you you have on line 157 of my_component.vhd?
    update:
    When adding "add_file my_fifo.vhd {SYNTHESIS SIMULATION}" to the _hw.tcl file, then in ModelSim the following error occurs:
    # ** Error: C:/Test/IP/my_component.vhd(157): (vcom-1141) Identifier "my_fifo" does not identify a component declaration.
    Where is the problem?
    When compiling the my_component.vhd outside the SOPC builder everything works...
    Does anyone has a hint for me?
