17 years agoSOPC ERROR: Cannot have an associated clock
Hi, I'm trying to generate a SOPC component from a VHDL file. I want to make an I2C component. The VHDL basis ist the I2C Master/Slave from opencores. I modified it in that way, that I only nee...
17 years agoHi again,
thanks for pushing me into the right direction . . . I just renamed my port map the way you suggested it and I don't have any errors and warnings anymore. For my VHDL module, that means that I have to rewrite some parts because it was meant to work a little bit different than I have to use it, now. But this should be possible. I wonder, how I can provide something like acknowledge to the Avalon system as there is no such signal type. Is it an uncommon request to have an acknowledge signal available? Well i try to figure out how all this is meant to work, therefore I appologize if I appear a little bit unexperienced. Maik
