16 years agoSOPC Custom Memory Component
I am trying to create a custom memory component to use with NIOS. I generated an Avalon MM Slave component and I can add it and it seems to connect fine. However, NIOS won't let me select it for the Reset or Exception vectors. Also, SOPC gives me a warning at the bottom saying that those vectors cannot be set until I add a memory device. So, it seems like SOPC does not recognize my component as a memory device. What do I need to add to the interface to make it show up as a memory device?
Thank you for your help Here is the verilog for the component (basic pass through).module my_ram (// Slave interface
input csi_clock_clk,
input csi_clock_reset_n,
input avs_s1_address,
input avs_s1_byteenable,
input avs_s1_read,
input avs_s1_write,
input avs_s1_writedata,
output avs_s1_readdata,
output avs_s1_waitrequest,
// Conduit
output coe_user_clk,
output coe_user_reset_n,
output coe_user_address,
output coe_user_byteenable,
output coe_user_read,
output coe_user_write,
output coe_user_writedata,
input coe_user_readdata,
input coe_user_waitrequest);
assign avs_s1_readdata = coe_user_readdata;
assign avs_s1_waitrequest = coe_user_waitrequest;
assign coe_user_clk = csi_clock_clk;
assign coe_user_reset_n = csi_clock_reset_n;
assign coe_user_address = avs_s1_address;
assign coe_user_byteenable = avs_s1_byteenable;
assign coe_user_read = avs_s1_read;
assign coe_user_write = avs_s1_write;
assign coe_user_writedata = avs_s1_writedata;
endmodule3 Replies
Thanks you kest . I was struggle with the same problem for two days.
Thank you so much Kest! that was it. It now works as intended.
In your .tcl file you should change something like
set_interface_property "as1" "isMemoryDevice" "false" to set_interface_property "as1" "isMemoryDevice" "true" Then your AVALON-component (as1) will be a memory Best regards, Kest
