17 years agoSOPC, Custom IP (Pass through) problem
Hi Everybody, I have quartus 8.0 running on cyclone iii Board with bitec's hsmc dvi daughterboard on it. I have clocked video input (1080p60 dvi input) and clocked video output (1080p60 dvi ...
17 years agomuclear,
I thought frame buffer was only necessary if you wanted to do some manipulation with the frame and that the CVI and CVO would be synchronized as long as you connect them to the same clock source. Then I read in one of the articles saying that I would need the frame buffer for synchronization problem, too. formjk and jakobjones also suggested that as well. Thanks for the warning. Today I will add the frame buffer into my project again and see how it will turn out. Tyler
