14 years agoSOPC Builder and nios ii help
hi... i am new to altera,currently am doing my final year project with altera cyclone ii...i dont know using SOPC builder and nios ii...kindly help me with that...thanks...
14 years agoThanks Mark
I've got another issue, while adding my top level variables in SOPC (so as to get them in system.h while building my hello_led.c in NIOS II), i'm facing signal width compatibility issues. The following are my input and output in toplevel; input clk, input reset, //inputs from low-level software (MAC/PHY) to my toplevel input [31:0] data_in_from_ethernet, input [1:0] data_in_from_ethernet_type, input cpu_ip_done, input [7:0] cpu_ip_index, input cpu_arp_done, input [2:0] cpu_arp_index, //inputs exchanged to my other modules input data_out_from_app_valid, input [31:0] data_out_from_app, input [31:0] dest_ip_addr, input [15:0] dest_port, input [15:0] data_out_from_app_length, //outputs from low-level software (MAC/PHY) to my toplevel output ack, output cpu_ip_ready, output [47:0] cpu_ip_mac, output [31:0] cpu_ip_data, output [7:0] cpu_ip_length, output cpu_arp_ready, output [47:0] cpu_arp_mac, output [31:0] cpu_arp_data, //outputs exchanged from my other modules output data_in_to_app_valid, output [31:0] data_in_to_app, output [15:0] input_port By default, it takes signal type as "export" and interface as "avalon_slave_0", which results in; # 2012.04.08 23:24:40 (*) Running Generator Program for cpu_0 ERROR: slave (toplevel_inst/avalon_slave_0) data width is 0 Error: Generator program for module 'cpu_0' did NOT run successfully. ---------------------------------------------------------------------- I tried setting all possible options for input and output, unable to proceed especially "cpu_ip_mac" whose width is 48 is not workingout. Is there an option to handle this width issue? Thanks Liana
