15 years agosome warning i can't handle it ; whether these warnings existence is ok?
this code is used for the scan the 4 * 4 matrix keyboard
module keyboard(
clk,rst_n,
kbcol,
kbrow,
Bites
input clk,rst_n;
input kbcol;
output kbrow;
output Bites;
reg count;
always @ (posedge clk or negedge rst_n) begin
if(!rst_n) count <= 0;
else if ( count == 4 ) count <= 0;
else count <= count + 1 ;
end
reg kbrow_r;
reg sta;
always @ ( count ) begin
case ( count )
2'b00 : begin
kbrow_r <= 4'b0001;
sta <= 4'b00;
end
2'b01 : begin
kbrow_r <= 4'b0010;
sta <= 4'b01;
end
2'b10 : begin
kbrow_r <= 4'b0100;
sta <= 4'b10;
end
2'b11 : begin
kbrow_r <= 4'b1000;
sta <= 4'b11;
end
default :;
endcase
end
assign kbrow = kbrow_r;
reg Bites_r;
always @ ( sta )
case ( sta )
2'b00 :
case (kbcol)
4'b0001: Bites_r <= 8'h0f;
4'b0010: Bites_r <= 8'h0e;
4'b0100: Bites_r <= 8'h0d;
4'b1000: Bites_r <= 8'h0c;
default : ;
endcase
2'b01 :
case (kbcol)
4'b0001: Bites_r <= 8'h03;
4'b0010: Bites_r <= 8'h06;
4'b0100: Bites_r <= 8'h09;
4'b1000: Bites_r <= 8'h0b;
default : ;
endcase
2'b10 :
case (kbcol)
4'b0001: Bites_r <= 8'h02;
4'b0010: Bites_r <= 8'h05;
4'b0100: Bites_r <= 8'h08;
4'b1000: Bites_r <= 8'h00;
default : ;
endcase
2'b11 :
case (kbcol)
4'b0001: Bites_r <= 8'h01;
4'b0010: Bites_r <= 8'h04;
4'b0100: Bites_r <= 8'h07;
4'b1000: Bites_r <= 8'h0a;
default : ;
endcase
default : ;
endcase
assign Bites = Bites_r;
endmodule
the main warning i was suspect is these warning : Warning (10235): Verilog HDL Always Construct warning at keyboard.v(57): variable "kbcol" is read inside the Always Construct but isn't in the Always Construct's Event Control Warning (10235): Verilog HDL Always Construct warning at keyboard.v(65): variable "kbcol" is read inside the Always Construct but isn't in the Always Construct's Event Control Warning (10235): Verilog HDL Always Construct warning at keyboard.v(73): variable "kbcol" is read inside the Always Construct but isn't in the Always Construct's Event Control Warning (10235): Verilog HDL Always Construct warning at keyboard.v(81): variable "kbcol" is read inside the Always Construct but isn't in the Always Construct's Event Control Warning (10240): Verilog HDL Always Construct warning at keyboard.v(54): inferring latch(es) for variable "Bites_r", which holds its previous value in one or more paths through the always construct Warning: Latch Bites_r[0] has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal kbcol[0] Warning: Latch Bites_r[1] has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal kbcol[2] Warning: Ports D and ENA on the latch are fed by the same signal kbcol[2] Warning: Latch Bites_r[2] has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal kbcol[1] Warning: Ports D and ENA on the latch are fed by the same signal kbcol[1] Warning: Latch Bites_r[3] has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal kbcol[2] Warning: Ports D and ENA on the latch are fed by the same signal kbcol[2] Warning: Timing Analysis is analyzing one or more combinational loops as latches Warning: Node "Bites_r[0]" is a latch Warning: Node "Bites_r[1]" is a latch Warning: Node "Bites_r[2]" is a latch Warning: Node "Bites_r[3]" is a latch Warning: Node "Bites_r[0]" is a latch Warning: Node "Bites_r[1]" is a latch Warning: Node "Bites_r[2]" is a latch Warning: Node "Bites_r[3]" is a latch Warning: Found 1 node(s) in clock paths which may be acting as ripple and/or gated clocks -- node(s) analyzed as buffer(s) resulting in clock skew Info: Detected gated clock "Mux8~0" as buffer Info: Detected gated clock "Mux8~0" as buffer please tell me the generate reason of these warning,and how to solve it ;thanks a lot ;1 Reply
TO_BE_DONE
