14 years agosome questions about Verilog from beginner:)
Hi everyone! Just started to learn Verilog language. Meet the problem in my first more or less serious project. Can you explain me please what does -1:0 mean in: input [input_width-1:0] x...
14 years agoINPUT_WIDTH and other parameters are simply constant definitions which allow you to easily manage code in case you need to change the value. If you are familiar with C programming, these are similar to a# define
So, if you have defined INPUT_WIDTH = 12, like in your sample code, input [INPUT_WIDTH-1:0] x; is exactly the same as input [11:0] x; and [INPUT_WIDTH+2:0] x; is the same as input [14:0] x; If you want to change width from 12 to 16, you only modify the parameter line and you don't need to keep track of all the places where that value is involved.
