10 years agoSome problems about altera_pll on cyclone V device
Hello everyone, I just met a problem about altera_pll on my cyclone V board. There is a 5CEFA4F23C8 FPGA on my board and the FPGA is conneted to a crystal oscillator via a clock input pin. ...
9 years ago --- Quote Start --- I faced the same problem and the PLL was not locking. The RREF_TL was left floating. The issue was partially solved after fixing this floating pin. --- Quote End --- Thank you for your advice, Sherif. Does your PLL work now? You mentioned that your issur has been partially solved. I wonder what issue has not been solved now.
