10 years agoSome problems about altera_pll on cyclone V device
Hello everyone, I just met a problem about altera_pll on my cyclone V board. There is a 5CEFA4F23C8 FPGA on my board and the FPGA is conneted to a crystal oscillator via a clock input pin. ...
10 years ago --- Quote Start --- Thank you for your advice, derim。 I just confirmed the input pins and found it correctly connected to the dedicated CLK3_P pin , so as my teammates. If I use the external clock directly, the clock is OK. But if only the altera_pll exists, the system fails. --- Quote End --- Additional obvious check: is the reset pin pulled low? The PLL expects an active-high reset, not active low. In addition, is the PLL set to auto-lock in the settings?
