Some help with code
- 2 years ago
in principle, there's nothing against designing a pure combinational FPGA, e.g. a binary to seven-segment decoder as shown above.
By design, unregistered combinational logic has output glitches, but that's not necessarily a problem for a seven-segment decoder.
The worst point of the present design is the ineffective way to implement binary to BCD conversion. In an FPGA implementation, look-up table would be the best resource saving solution. Without block RAM, double dabble algorithm can reduce logic cell count.
Apart from ineffective implementation, I don't see a problem with code. It's producing correct output.
If it's intended as HDL learning project, I agree that synchronous design is preferred.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
