Solution: USB Blaster Driver for Windows 11 ARM
Reddit user Space192 and I found a driver solution for the USB Blaster on Windows 11 ARM. It has been tested on Windows 11 ARM Parallels for M1/M2 Macs and also on a Raspberry Pi 4. The solution is to use the FTDI ARM64 .SYS file with the Quartus USB Blaster x64 .DLL files.
To install the attached driver without disabling signature enforcement and enabling test mode, first add the security certificate to Trusted Root Certification Authorities as well as Trusted Publishers.
Enjoy!
The USB Blaster driver attached to my original post should work for Quartus 19.1 through 23.3 on Windows 11 ARM.
I've attached proven drivers for Quartus 17 through 18, Quartus 13, and Quartus 9. To install a driver without disabling signature enforcement, first add the security certificate to (Local Machine) Trusted Root Certification Authorities as well as (Local Machine) Trusted Publishers.
If you have a version of Quartus not listed, the ARM driver version with DLL file sizes matching those found in \quartus\drivers\usb-blaster\x64\ should work. If there is no match, replacing the DLL files of any ARM driver version and disabling driver signature enforcement should work.
- Farabi_Altera
Thanks for the information sharing ! I will try to put this into our KDB(knowledge database) so everyone can get this information.
regards,
Farabi
