Solution: USB Blaster Driver for Windows 11 ARM
- 3 years ago
The USB Blaster driver attached to my original post should work for Quartus 19.1 through 23.3 on Windows 11 ARM.
I've attached proven drivers for Quartus 17 through 18, Quartus 13, and Quartus 9. To install a driver without disabling signature enforcement, first add the security certificate to (Local Machine) Trusted Root Certification Authorities as well as (Local Machine) Trusted Publishers.
If you have a version of Quartus not listed, the ARM driver version with DLL file sizes matching those found in \quartus\drivers\usb-blaster\x64\ should work. If there is no match, replacing the DLL files of any ARM driver version and disabling driver signature enforcement should work.
Hello!. I'm currently trying to use Quartus 22.1.2 on Windows 11 ARM. The driver you supplied worked well and device manager recognizes the USB Blaster. However, the hardware setup in Quartus Programmer fails to recognize the board. Does anyone have any idea how I could solve that? I already tried the newest Quartus version and the issue remains.
