Solution: USB Blaster Driver for Windows 11 ARM
- 3 years ago
The USB Blaster driver attached to my original post should work for Quartus 19.1 through 23.3 on Windows 11 ARM.
I've attached proven drivers for Quartus 17 through 18, Quartus 13, and Quartus 9. To install a driver without disabling signature enforcement, first add the security certificate to (Local Machine) Trusted Root Certification Authorities as well as (Local Machine) Trusted Publishers.
If you have a version of Quartus not listed, the ARM driver version with DLL file sizes matching those found in \quartus\drivers\usb-blaster\x64\ should work. If there is no match, replacing the DLL files of any ARM driver version and disabling driver signature enforcement should work.
After trying every solution suggested in the replies and disabling the signature enforcement, I've decided to go one by one and install all the drivers manually by right-clicking the usbblstr.inf file and manually install and authorize it by overriding system protection. After doing that the device manager started identify the device and I'm now able to use it with the 23.1 programmer.
Thank you everyone!
