Solution: USB Blaster Driver for Windows 11 ARM
- 3 years ago
The USB Blaster driver attached to my original post should work for Quartus 19.1 through 23.3 on Windows 11 ARM.
I've attached proven drivers for Quartus 17 through 18, Quartus 13, and Quartus 9. To install a driver without disabling signature enforcement, first add the security certificate to (Local Machine) Trusted Root Certification Authorities as well as (Local Machine) Trusted Publishers.
If you have a version of Quartus not listed, the ARM driver version with DLL file sizes matching those found in \quartus\drivers\usb-blaster\x64\ should work. If there is no match, replacing the DLL files of any ARM driver version and disabling driver signature enforcement should work.
Try adding the certificate to the Local Machine certificate store locations. I had a problem using the Current User certificate store locations.
I tried to install the original drivers on a Windows 11 Intel 64 bits, and I did get the same error message. It looks like the problem lies somewhere else. I did have to disable signature enforcement on that machine too in order to install the drivers.
It was a freshly installed Windows 11, latest version.
