12 years agosolution for mcu to configure ALTERA FPGA
Hello, i'm trying to use a MCU(like C8051) to configure Cyclone IV device(EP4CE30) in Passive Serial mode. In the past, i was using GPIO of MCU to simulate the configure timing. But configure sp...
12 years agoYour solution looks fine.
There are a couple of things you need to consider; 1. If your microcontroller has DMA, then that can be used to reduce the CPU work-load. 2. Where is your configuration data going to come from? A good option for configuration data storage is SPI or Quad SPI Flash. If your microcontroller has two SPI interfaces, this might be a good option. However, you will need to check that you can DMA from one interface to another. For example, Quad SPI is fast, so is often located on a "fast" internal bus, whereas SPI is low, so is often located behind a "slow" bridge. I prefer to avoid these types "complications" by using a MAX II CPLD as the configuration controller. Eg., see http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf Cheers, Dave
