10 years ago
software for flex 10k
I need to make a modification on an old design which used a Flex 10KA device. Which is latest version of Altera software that I can to use which will support this family? Is Quartus II 9.0 the latest version with this device support?
    To avoid the compatibility issue, you should use Max+Plus2 if your existing design was created with it.
    Thanks Tricky. Does this mean I should load the Max+Plus2 software to my PC instead of Quartus?
    Yes, Quartus 9 is the latest that will compile for Flex10k
    But Ive had problems with old Max + Plus2 designs not working in Quartus, so I had to use Max+Plus2.
