sof is incomplete. Hps is present but bootloader information is missing
Hello !
I am working with HPS for ethernet application on Stratix 10 Development kit on Windows.
I tried using the s10-soc-devkit-ghrd example on Quartus Prime pro 2023.
However, when I launch the programmer or the programming file generator, I always receive the same error : ghrd_1sx280lu2f50e2vg.sof is incomplete. Hps is present but bootloader information is missing.
I tried following the commands present on RoketBoard for project building, however nothings does I still don't understand how to add the bootloader to SOF.
Can someone please explain me how I can add the bootloader to the sof?
- aikeu
Hi emiwane,
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
Aik Eu
- aikeu
- aikeu
Hi emiwane,
FYI, you can get the pre-built files from example like the jic file from :
https://releases.rocketboards.org/2023.04/gsrd/s10_gsrd/
Are you following the steps from building bootloader for Stratix10 to prepare the QSPI image, referring to Prepare QSPI Image section where it uses nios2 command shell to perform the sof file conversion to jic.
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderStratix10
Aik Eu
- emiwane
Hi Aik Eu,
Thank you for your answer. However I can't generate the ghrd_1sx280lu2f50e2vg.jic, I receive the same error
Emeline
- aikeu
Hi emiwane,
Referring to this document:
https://www.rocketboards.org/foswiki/Documentation/Stratix10SoCGSRD
When configuring the board(Running GSRD with Pre-Built Binaries), you must flash in the QSPI flash with
ghrd_1sx280lu2f50e2vg.jic first before booting up with sd card
Aik Eu
