emiwane
3 years agosof is incomplete. Hps is present but bootloader information is missing
Hello ! I am working with HPS for ethernet application on Stratix 10 Development kit on Windows. I tried using the s10-soc-devkit-ghrd example on Quartus Prime pro 2023. However, when I launch th...
aikeu
3 years agoHi emiwane,
FYI, you can get the pre-built files from example like the jic file from :
https://releases.rocketboards.org/2023.04/gsrd/s10_gsrd/
Are you following the steps from building bootloader for Stratix10 to prepare the QSPI image, referring to Prepare QSPI Image section where it uses nios2 command shell to perform the sof file conversion to jic.
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderStratix10
Aik Eu
