14 years agosof and pof file not generated
After a long time i am using quartus ii software.i have developed a cyclone 3 FPGA board. for testing i use quartus ii 7.2 web edition software. it is not generatng sof and pof file. i used cyclone 3 device ( EP3C16Q240C8N ). i also have terasic De1 board. i select this kit device then it generate sof and pof file. Please any one provide me some solution. Regards, Shahul8 Replies
Hi HJS,
Thank u very much "set_global_assignment -name USE_CONFIGURATION_DEVICE ON" this command works for me. my new board is ready :-) - Altera_Forum
Hi HJS,
"set_global_assignment -name USE_CONFIGURATION_DEVICE ON" this command works for me my new board is ready :-) - Altera_Forum
Are you using any unlicensed IPs? If it generates a time limited .sof, then it won't generate programming files.
I don't know why a pof is generated when you are choosing a Cyclone II device. But you can convert the sof to pof in quartus : File-> Convert Programming Files. An other way is to add the string "set_global_assignment -name USE_CONFIGURATION_DEVICE ON" in your qsf. Then the pof is automatically generated. Regards, HJS - Altera_Forum
Now i got working of my fpga (EP3C16Q40C8N) Ic.After using quartus-ii 11.1 sp2. it only generate SOF file,not POF file. i don't know what is the reason? i am using epcs4 prom in the board. when i change the device to cyclone 2 instead of cyclone3 it generate POF file. Please give me some idea. i am using older version license.any problem with its license? - Altera_Forum
k thank u for our respone HJS.
Now i am downloading latest version 11. i hope it will do it. - Altera_Forum
Quartus 7.2 has only advanced device support for the EP3C16 devices, which does not generate programming files. You have to update your quartus version. Regards, HJS - Altera_Forum
It shows warning message
Info: Compilation Report contains advance information. Specifications for device EP3C16Q240C8 are subject to change. Contact Altera for information on availability. No programming file will be generated.
