11 years agoSOCkit Hard Processor System - problems getting started (unassigned pins, vhdl lib)
I've been working on FPGAs now for a year or so - building my own Atari 800XL clone in hardware. This is running on several boards using pure VHDL, except for the PLL. On all other boards I'm using a...
11 years agoI've been through the same Mao III tutorial and have the same questions as# 2 and# 3 above. One thing I still don't understand is: if you look at the pdf schematic (watermarked by Terasic) that comes with the SoCKit SystemCD, the pins to the Cyclone V generally don't match the HPS pins assigned by the fitter after full compilation. For example, after compilation, the fitter assigns hps_memory_mem_a[14] to PIN_AJ2 on the Cyclone; but when I look at the Terasic schematic sheet 3 of 30, PIN_AJ2 seems to be connected to the VGA port.
I suppose it's something simple I'm missing, but for now i am perplexed. I have SoCKiT rev c board and documentation. Of course, it also doesn't give me a warm and fuzzy that Terasic has the part# wrong on the schematic.
