11 years agosmall boot copier for EPCS
I have a customized board, with 5CEBA4 and EPCS16. I want the FPGA boot from a specified SW image address after the HW image is loaded. I studied AN458, and I think the small boot copier is go...
11 years agoI can't access Quartus right now in order to check, but if I remember correctly, you simply need to point to the right bootloader hex in the epcs device properties in Qsys/SOPC builder.
Then, again in Qsys, in Nios properties, you set epcs base address as nios reset vector
