11 years agosmall boot copier for EPCS
I have a customized board, with 5CEBA4 and EPCS16. I want the FPGA boot from a specified SW image address after the HW image is loaded. I studied AN458, and I think the small boot copier is go...
11 years agoHi Cris,
I think I have maken some progress. I forget to associate the hex file to the boot_rom in the Qsys, because the AN458 doesn't tell me to do it. I also managed to compile the small_boot_copier.s with Quartus 11.0. Now, the performance of my board is. The hw boot normally, then the sw image is copied. Then the hw lost. I checked the binary file of the my sw, and I found the destination address(2nd 4 bytes) is set to 0x1000, which is the cpu address. I have checked the bin file of the sw before, the destination address is set to 0x200020. My nios address is: cpu 0x1000 sram 0x200000 boot_rom 0x1c00 epcs 0x0 I also set the reset_vector to 0x1c00, and exception vector to 0x200020. In Nios2 SBT, the bsp editor showes all the linker section are pointing to sram, except .entry to boot_rom. Do you know where to set this destination address? Thank you very much. Please forgive me for my bad english. Derek
