11 years agosmall boot copier for EPCS
I have a customized board, with 5CEBA4 and EPCS16. I want the FPGA boot from a specified SW image address after the HW image is loaded. I studied AN458, and I think the small boot copier is go...
11 years agoHi Cris,
When I try to make the small_boot_copier, it always halt after echo "compiling to obj / small_boot_copier.elf". And after I key in "Ctrl+C", the programmer goes on, but this hex file doesn't work. I am using Quartus 13.1 with NIOS2 command shell [gcc4]. The command elf2flash can work only when I start the shell from Qsys->tool. But this shell also halts when I make the small_boot_copier. I am puzzled with this issue. Could you please give me some suggestion? Thank you very much. Derek http://www.alteraforum.com/forum/attachment.php?attachmentid=9794&stc=1
