11 years agosmall boot copier for EPCS
I have a customized board, with 5CEBA4 and EPCS16. I want the FPGA boot from a specified SW image address after the HW image is loaded. I studied AN458, and I think the small boot copier is go...
11 years agoHi Cris72,
Thank you very much for you reply. I guess I miss-understand the source code of small_boot_copier.s. Besides, I think if I don't have the header in the image file, I can skip the header check by comment the following code directly: // Check the boot image signature nextpc return_address_less_4 br read_32b_from_flash mov temp_data, return_value movhi expected_value, %hi(VALID_BOOT_SIGNATURE) ori expected_value, expected_value, %lo(VALID_BOOT_SIGNATURE) bne temp_data, expected_value, error // Now we can begin copying the boot record to RAM. This loop // reads each individual record in the boot record, and copies it // to the appropriate location in RAM. If the record is a JUMP // record, the loop breaks and branches to the address indicated // in the JUMP record. // Increment flash_ptr by 28 to skip past the boot image header and into // the real boot record (we already incremented it by 4 when we read the // signature) // // You may wish to do more with the header information than just skip // past it. If so, this is the place to do that. addi flash_ptr, flash_ptr, 28 Am I right? Thanks again. Derek
