13 years agoSingle wire can bus and bidirectional pin coding
Hi all, I am a beginner, trying to implement a One-wire CAN bus coupler logic on a Cyclone IV FPGA. The FPGA communicates to a disconnectable external slave device via a pin using CAN bus...
12 years ago --- Quote Start --- I think, the question can't be answered without an exact specification of intended behaviour. --- Quote End --- The register that I am concerned about: A simple system connection: MCU <====SPI====> FPGA <==1-wire CAN=> SLAVE device(s) 1. The FPGA detects one or more slave devices (i.e. max of 8). 2. FPGA updates its register for each of the 8 devices. (i.e. 1' for connected, '0', for disconnected) 3. FPGA sends an interrupt to notify the MCU about new devices 4. MCU uses SPI to read the registers FPGA, and writes back to the same register with respective '0's once it has processed the newly connected device(s). The point to note is that it might be possible for devices to be connected at any time. Meaning there is a chance there is write contention on the register. Unfortunately I am unable to change the process on how the device registration takes place, as this is specified in the specifications. --- Quote Start --- Obviously it's impossible for a bidirectional output with tristate driver. --- Quote End --- Thanks, I thought it might sound stupid but I'd ask anyway.
