13 years agoSingle wire can bus and bidirectional pin coding
Hi all, I am a beginner, trying to implement a One-wire CAN bus coupler logic on a Cyclone IV FPGA. The FPGA communicates to a disconnectable external slave device via a pin using CAN bus...
13 years agoThanks! I will try it out and update here.
--- Quote Start --- In FPGAs, do not use tri-state logic outside the top level module. Instead, if you need to connect your bidir_port to modules inside your toplevel, use the trio of bidir_port_i, bidir_port_oe and bidir_port_o. --- Quote End --- On the above point, is it important for me to put the tristate code on the top level, even if my bidir_port module's bidir signal is connected directly to the output pin on the top level?
