13 years agoSingle wire can bus and bidirectional pin coding
Hi all, I am a beginner, trying to implement a One-wire CAN bus coupler logic on a Cyclone IV FPGA. The FPGA communicates to a disconnectable external slave device via a pin using CAN bus...
13 years agoThe first thing is that you need to model the open-drain and the pull-up separately.
You should have a testbench which models the pull up by always driving the signal with a weak high, while also connecting it to slaves.bidir_bus_signal <= 'H';
slave1 : my_slave
port map (
bidir_port => bidir_signal,
); Then, inside your slave_controller, you implement the open drain by driving the port with either '0' or 'Z'.
bidir_port_i <= to_x01(bidir_port);
bidir_port <= '0' when bidir_port_oe = '1' and bidir_port_o = '0' else 'Z'; Your slave logic should drive the bidir_port_oe and bidir_port_o signals to drive the output and it should read from bidir_port_i to read the input. A couple of implementation details: - Quartus knows the code template above and it will set the I/O driver to open-drain. - In FPGAs, do not use tri-state logic outside the top level module. Instead, if you need to connect your bidir_port to modules inside your toplevel, use the trio of bidir_port_i, bidir_port_oe and bidir_port_o.
