Single-Ended I/O Performance on MAX10
- 7 years ago
The answer to your question is that Altera/Intel no longer supplies single-ended toggle rate information. They tell you to do an IBIS simulation. This is very frustrating when all you typically want to know is whether "low speed" means 100Mhz, 10Mhz or 1Mhz.
- akohlsmith7 years ago
Hello Sree,
I don't think that you answered my question. You are correct that the maximum data rate for *differential* I/O standards is well-documented. I am asking about the maximum data rate for *single-ended* I/O standards. I cannot, for instance, find how fast a "Low Speed" I/O pin can toggle when operating as a 3.3V LVCMOS I/O standard on a M1025DAF256C8.
The datasheet says that this information is in the pinout file, but the changelog in the pinout file says that this information was removed in December 2016.
Where can I find the I/O toggle rates for single-ended I/O standards?
Thank you,
Andrew
