10 years agoSimulation of timing analysis in ModelSim-Altera ??!!!
Hey guys , this is my first time to use the ModelSim-Altera analysis tool. I followed many tutorials and I know how to set the parameters of the TimeQuest and I get correct compilation of the TimeQue...
10 years ago --- Quote Start --- Well , I mean for example if im designing an adder , thats fully combinational design which needs no clock , but to get appropriate timing analysis I have to make it work with clock like latch the operands into registers and latch the output . Im asking if there is some other way in which I can give up the clock and just get the latency between the inputs and output of the adder? --- Quote End --- That is rtl we are talking about. combinatorial clouds sandwiched between registers. TQ takes care of delays as comb decisions are sampled at clock edge. if it passes timing you don't need to see delay values.
