16 years agoSimulation in Quartus 10
Hi all, I was used to simulate my project with the simulation tool in earlier version of quartus but now, this tool is no longer available with the version 10.0 and I have to use ModelSim. ...
16 years agoif you still have 9.1sp2 or earlier installed you can create an HDL test bench from your .vwf
as mentioned you can also create an HDL file for the .bdf. your Megafunctions should all have a source file in an HDL. be sure to create them all in the same HDL, as both versions of ModelSim-Altera only support a single HDL. when you create an HDL file from a .bdf, the .bsf are bypassed and the the source HDL for the .bsf is instantiated directly i would also take a look at Altera's NativeLink feature that automates running ModelSim for you
