15 years ago
Simulate problem about (altfp_sqrt) core
:confused::confused:In my program I just implement an IP core(altfp_sqrt) by using megawizard. however after simulation by modelsim, the result always shows as high Z.
Can any body help to solve this problem? Thank you very much!!!
/*****************program********************************/
module sqrt (clk, idin, dout);
input [31:0] idin;
output [31:0] dout;
input clk;
wire [31:0] idin;
wire [31:0] dout;
ddr ddr_sqrt (
.clock(clk),
.data(idin),
.result(dout)
always @ (posedge clk)
$display ("dout = ", dout);
endmodule
/**************test bench************************************/
module sqrt_tb;
reg clk;
reg [31:0] data;
wire [31:0] idin; // data in
wire [31:0] dout; // data out
assign idin = data;
always# 10 clk = ~clk;
initial
begin
clk = 0;
data = 'b100;
end
sqrt m(clk, idin, dout);
endmodule
    /***************Top Module ****************/
    module fp_sqrt (clk, idin, dout);
    input clk;
    input [31:0] idin;
    output [31:0] dout;
    wire [31:0] idin;
    wire [31:0] dout;
    sel_sq fp_sqrt_sq (
    .clock(clk),
    .data(idin),
    .result(dout)
    begin
    $display ("idin= ", idin);
    end
    endmodule
    /****************ALTFP_SQRT CORE********************/
    // megafunction wizard: %ALTFP_SQRT%VBB%
    // GENERATION: STANDARD
    // VERSION: WM1.0
    // MODULE: altfp_sqrt
    // File Name: sel_sq.v
    // Megafunction Name(s):
    // altfp_sqrt
    // Simulation Library Files(s):
    // lpm
    // THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
    // 10.1 Build 197 01/19/2011 SP 1 SJ Full Version
    //Copyright (C) 1991-2011 Altera Corporation
    //Your use of Altera Corporation's design tools, logic functions
    //and other software and tools, and its AMPP partner logic
    //functions, and any output files from any of the foregoing
    //(including device programming or simulation files), and any
    //associated documentation or information are expressly subject
    //to the terms and conditions of the Altera Program License
    //Subscription Agreement, Altera MegaCore Function License
    //Agreement, or other applicable license agreement, including,
    //without limitation, that your use is for the sole purpose of
    //programming logic devices manufactured by Altera and sold by
    //Altera or its authorized distributors. Please refer to the
    //applicable agreement for further details.
    module sel_sq (
    clock,
    data,
    result)/* synthesis synthesis_clearbox = 1 */;
    input clock;
    input [31:0] data;
    output [31:0] result;
    endmodule
    /**********************testbench*************************/
    input clk;
    input [31:0] idin;
    output [31:0] dout;
    wire [31:0] idin;
    wire [31:0] dout;
    sel_sq fp_sqrt_sq (
    .clock(clk),
    .data(idin),
    .result(dout)
    begin
    end
    endmodule
    thank you . but I checked the altfp_sqrt module name is right.
    And I re-do the whole program, it still has the same problem.
    ddr ddr_sqrt (
         .clock(clk),
         .data(idin),
         .result(dout)
    Check that your MegaWizard generated altfp_sqrt module instance is indeed named "ddr".
