15 years agoSimulate problem about (altfp_sqrt) core
:confused::confused:In my program I just implement an IP core(altfp_sqrt) by using megawizard. however after simulation by modelsim, the result always shows as high Z. Can any body help to solve t...
15 years ago/***************Top Module ****************/
module fp_sqrt (clk, idin, dout); input clk; input [31:0] idin; output [31:0] dout; wire [31:0] idin; wire [31:0] dout; sel_sq fp_sqrt_sq ( .clock(clk), .data(idin), .result(dout) ); always @ (posedge clk) begin $display ("idin= ", idin); $display ("dout = ", dout); end endmodule /****************ALTFP_SQRT CORE********************/ // megafunction wizard: %ALTFP_SQRT%VBB% // GENERATION: STANDARD // VERSION: WM1.0 // MODULE: altfp_sqrt // ============================================================ // File Name: sel_sq.v // Megafunction Name(s): // altfp_sqrt // // Simulation Library Files(s): // lpm // ============================================================ // ************************************************************ // THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE! // // 10.1 Build 197 01/19/2011 SP 1 SJ Full Version // ************************************************************ //Copyright (C) 1991-2011 Altera Corporation //Your use of Altera Corporation's design tools, logic functions //and other software and tools, and its AMPP partner logic //functions, and any output files from any of the foregoing //(including device programming or simulation files), and any //associated documentation or information are expressly subject //to the terms and conditions of the Altera Program License //Subscription Agreement, Altera MegaCore Function License //Agreement, or other applicable license agreement, including, //without limitation, that your use is for the sole purpose of //programming logic devices manufactured by Altera and sold by //Altera or its authorized distributors. Please refer to the //applicable agreement for further details. module sel_sq ( clock, data, result)/* synthesis synthesis_clearbox = 1 */; input clock; input [31:0] data; output [31:0] result; endmodule /**********************testbench*************************/ module fp_sqrt (clk, idin, dout); input clk; input [31:0] idin; output [31:0] dout; wire [31:0] idin; wire [31:0] dout; sel_sq fp_sqrt_sq ( .clock(clk), .data(idin), .result(dout) ); always @ (posedge clk) begin $display ("idin= ", idin); $display ("dout = ", dout); end endmodule
