12 years agoSimple State Machine Problem
I attach a basic four state machine project file built with schematic and state machine wizard via Quartus 2 sp2. Its basic operation theoretically must follow this table below: sentido = 0; enable = 0; state = Scurr sentido = 0; enable = 1; state = Sn-1 sentido = 1; enable = 0; state = Scurr sentido = 1; enable = 1; state = Sn+1 Scurr = current state The states are: s0 (Q1 = 1; Q0 = 1), s1 (Q1 = 1; Q0 = 0), s2 (Q1 = 0; Q0 = 0), s3 (Q1 = 0; Q0 = 1), My Cyclone II FPGA Starter Board is not showing the LEDG[1] and LEDG[0] leds alternating their values at 1,49 Hz according to my SW[1] and SW[0] switches states ("10" or "00"). "sentido" in portuguese is equal to "direction". Any idea why this project file doesn´t produce the desired outputs? Regards Jaraqui3 Replies
Just a comment: the website forbidds .rar attachments. So I renamed this file to a .zip one. The original is .rar. It can be unzipped without problems.
You have a bad connection in your schematic on LEDG1. Probably this cause the problem.
There is something that doesn't look good in the state register description. You mix the asynchronous reset with the next state logic of the state machine: IF (reset='0') THEN reg_fstate <= s0; reg_Q1 <= '0'; reg_Q0 <= '0'; ELSE reg_Q1 <= '0'; reg_Q0 <= '0'; ... The orthodox way is: PROCESS (clock,reg_fstate,reg_Q1,reg_Q0) BEGIN IF (reset='0') THEN reg_fstate <= s0; reg_Q1 <= '0'; reg_Q0 <= '0'; ELSIF (clock='1' AND clock'event) THEN fstate <= reg_fstate; Q1 <= reg_Q1; Q0 <= reg_Q0; END IF; END PROCESS; PROCESS (fstate,reset,sentido,enable) BEGIN reg_Q1 <= '0'; reg_Q0 <= '0'; CASE fstate IS WHEN s0 => IF (((sentido = '1') AND (enable = '1'))) THEN reg_fstate <= s1; ... The last thing. You design a clock divider. This is not the best way to slow a clock. Altera and Quartus can implement it but can lead to timing problems in more complex design. The prefered way is with clock enables. ¡Éxitos! - Altera_Forum
Dear bertulus,
Thank you for your precise comments and recommendations. I will post the modifications and the respective results obtained afterwards. Best regards, Jaraqui
