Simple socket server - NIOS question
We are using simple socket server template in eclipse. Arria 10 GX devkit is used as hardware. Can see that ethernet link is established from NIOS console. But would like to understand if ping/icmp is supported in simple socket server example?
we are trying to ping the board from host pc, but no success. Can you tell us if icmp/ping is supported in simple socket server template from Eclipse? or should we do something from our end?
The icmp/ping function works on the Simple Socket Server example but ONLY on the Quartus 17.1 pro version. The Quartus version that you are using(18.1) cannot support the design example and ping function provided by Intel here: https://www.intel.com/content/www/us/en/design-example/714912/arria-10-nios-ii-simple-socket-server-design-example.html
I would suggest you to use Quartus 17.1 pro version to try out the design example above.
Thank you.
Kelly
- MK_ABQ
Contributor
Hi Kelly,
Sorry about my delayed reply. Tried the project again with 18.1 standard version. Made some tweaks for our custom board, and built from scratch, and its working now.
