10 years agosimple pin to pin delay managing in Cyclone
Hi everybody, I want to know just a simple thing. I'm going to use my FPGA as a bypass element for a bus. Imagine, I have a couple of inputs "INPUT_1" and "INPUT_2", and I'm going to redir...
10 years ago --- Quote Start --- This is not something you can guarantee at all through an FPGA - it will be affected by process, voltage and temperature fluctuations. Timequest will only ever give you a worst case estimate, never an exact figure. --- Quote End --- Ok I understand, imagine temperature and voltage fluctuations are stables and are not going to be problem... I simple want to know how can I constraint a couple of input to output convinational pins doing a bypass function and, to be more clear, not related between them for any function. That what I want to know is how to constraint "exactly" the delay of each couple (input to output) or if it could be possible the delay of both couples intended as a group. But as a note: take into account, here, there is no reference clock. Thanks Jordi
