11 years agoSimple pin assignments using text file
Hi, I am just starting out with Quartus II Free 13.1 using an EP3C40U48417 device. We use the device in the main to allow us to change peripheral to processor pin allocations. Our processor ha...
11 years agoThanks, I will have a look.
I want to be able to create a definition of pin inputs to pin outputs using text file(s). In this way I can write a Windows program to generate the definition of what FPGA input pin connects to what FPGA output pin. This would remove a lot of manual steps involved in keeping various project definitions aligned. I am used to using ISVLever & in that tool you could specify pin assignments using a text constraints file.
