17 years agosigned/unsigned multipliers
I can't seem to find a way to instantiate a multiplier that will dynamically select between signed and unsigned multiplication. This is on a Cyclone II, but applies to other parts as well. Read...
17 years ago --- Quote Start --- the operand is signed the operands need to be converted to positive format, multiplied then converted to negative at the end if the signs are different. --- Quote End --- I agree and the math proof is very straightforward: n * -m = - (n * m) -n *m =-(n*m) so just convert -m to +m, multiply as unsigned, convert result back to negative. The overheads include two setd of inverter + two adders but: -m * -n = +(n*m) convert sign inputs but not output. I wonder if Trick have a math proof for his trick By the way here is a 2's complement puzzle: + => - invert bits then add 1 - => + invert bits then add 1 ?? how come this correct (or take 1 then invert bits, makes more sense) --- Quote Start --- Not commenting at all on the logistics of signed/unsigned multiplications, but more on synthesizable code, if you write: signal sum : signed(3 downto 0); IF(inc = '1') THEN sum <= sum + 1; ELSIF(dec = '1') THEN sum <= sum - 1; ELSE sum <= sum; END IF; It will usually generate two adders and then mux the output together. However, if you were to write: signal inc : integer range -1 to 1; signal sum : signed(3 downto 0); inc <= -1 when dec = '1' else 1 when inc = '1' else 0; sum <= sum + inc; Then it will usually generate a single adder with a mux at one of the input ports. Obviously the summation should be in a clocked process, but i am being lazy. Just a thought. Kevin --- Quote End --- True, compiler instantiates one operation unit per operand occurence. It doesn't want to know your intentions. I refrred to this ages ago regarding multipliers, to avoid this use one (*) assignment only then switch your inputs/outputs as you wish.
