17 years agosigned/unsigned multipliers
I can't seem to find a way to instantiate a multiplier that will dynamically select between signed and unsigned multiplication. This is on a Cyclone II, but applies to other parts as well. Read...
17 years agoNot commenting at all on the logistics of signed/unsigned multiplications, but more on synthesizable code, if you write:
signal sum : signed(3 downto 0); IF(inc = '1') THEN sum <= sum + 1; ELSIF(dec = '1') THEN sum <= sum - 1; ELSE sum <= sum; END IF; It will usually generate two adders and then mux the output together. However, if you were to write: signal inc : integer range -1 to 1; signal sum : signed(3 downto 0); inc <= -1 when dec = '1' else 1 when inc = '1' else 0; sum <= sum + inc; Then it will usually generate a single adder with a mux at one of the input ports. Obviously the summation should be in a clocked process, but i am being lazy. Just a thought. Kevin
