17 years agosigned/unsigned multipliers
I can't seem to find a way to instantiate a multiplier that will dynamically select between signed and unsigned multiplication. This is on a Cyclone II, but applies to other parts as well. Read...
17 years agoI think Tricky's workaround is not far off, except that the multiplier should be specified as having signed inputs. Then either sign- or zero-extend each input (by 1 bit, say) based on whether it is a signed or unsigned value, which is trivial. That way, any unsigned value will always become a positive signed value, and a signed value will retain its sign.
I still don't understand why signa and signb aren't available though.
