17 years agosigned/unsigned multipliers
I can't seem to find a way to instantiate a multiplier that will dynamically select between signed and unsigned multiplication. This is on a Cyclone II, but applies to other parts as well. Read...
17 years agoI am not sure if your input bus resize is doing what you want.
I suggest you instantiate two mult(signed,unsigned) then connect inputs to both. switch the output per input_sign.
