16 years agoSignalTap problems
Hi, I am trying to figure out the reason behind a problem I am having with SignalTap. I am using the triple speed ethernet core on a Stratix GX II FPGA. My FPGA board is connected to a PC...
16 years agoAre you perhaps using the wrong clock in signaltap to look at the outgoing data? Also, is it possible you've got the bits reversed in the signaltap setup for the data fields?
Jake
