16 years agoSignalTap needs only M9K memory in Quartus II 9.1
Helllo members.
I got a problem while designing using Quartus II 9.1 SP2 with signalTap. SignalTap always uses M9K memory even though I set the memory type AUTO during fitting. Does anyone have a solution?4 Replies
Thank you Tricky.
I done that already. But, it made an error. I can not remember the exact error messages but the key point was M144K can not be used for two-port memory. - Altera_Forum
Then set it to use M144k
On auto, it just uses whatever is available. It should never use already assigned memory. - Altera_Forum
I already used M9K memories in the design and have not much of remaining M9K memories to use with SignalTap while M144K memories are not used at all.
--- Quote Start --- Helllo members. I got a problem while designing using Quartus II 9.1 SP2 with signalTap. SignalTap always uses M9K memory even though I set the memory type AUTO during fitting. Does anyone have a solution? --- Quote End --- Hi, what is your problem with the use of M9K ? Kind regards GPK
