10 years agoSignalTap-II -> "instance not found" error
Hi all, I'm receiving the "instance not found" error on the SignalTap-II - attached please find the window snapshot. Actually the error occurred when I added signals for debug. I did the full ...
10 years agoGo to assignments -> settings > SignalTap II Logic Analyzer.
Here you need to tick the "Enable SignalTap II Logic Analyzer" and select the correct file before you compile the design.
