10 years agoSignalTap-II -> "instance not found" error
Hi all, I'm receiving the "instance not found" error on the SignalTap-II - attached please find the window snapshot. Actually the error occurred when I added signals for debug. I did the full ...
10 years agoAre you sure you're programming the correct file? have to loaded the correct .stp file? This can occur if the .stp file you're using for signaltap doesnt match the core in the device.
