[SignalTap] copy/paste/duplicate signals + seeing the same signal in several groups
Hi All,
No, run-time triggers are standard Signal Tap instance that run when your design is running in hardware. A power-up trigger is a child instance of a run-time trigger that lets you capture trigger events that occur after device programming but before you can open the .stp file and click "Run Analysis". Right-click a Signal Tap instance in the .stp Instance Manager to enable it.
- SyafieqS
- SyafieqS
Dmitry,
Let me know if there is any update or concern on this
- amildm
Contributor
"The only copy allowed is between a run-time trigger" - what do you mean "run-time trigger"? signals, which are defined to be also triggers?
- sstrell
- sstrell
1) Interesting idea, but no, there's no way to do this.
2) Again, unfortunately, no. The only copy allowed is between a run-time trigger and it's associated power-up trigger, if you use that feature.
